Raspberry Pi Pico RP2040 - Cortex-M HardFault Exception
    • Raspberry Pi Pico RP2040 - Cortex-M HardFault Exception
      Hi!
      I'm using a Segger J-Link Edu mini to debug a Raspberry Pi Pico RP2040.
      For simplicity, I am trying a blink example with Arduino.
      Ozone uploads and starts debugging, but soon reports a Cortex-M HardFault Exception. with three lines.
      1. CPU / Peripherals / SCB / SHCSR / SVCALLPENDED
      2. CPU / Peripherals / SCB / CCR / STKALIGN
      3. CPU / Peripherals / SCB / CCR / UNALIGN-TRP
      I had a look at the dedicated Wiki page for explanations, but can't find how to fix the issue.
      I have a similar issue when using the command line tools and arm-none-eabi-gdb.
      Shell-Script
      1. JLinkGDBServer -device RP2040_M0_0 -if swd -speed 1000
      Thank you for your help.
      Exact configuration is:
      • Arduino 1.8.13
      • Arduino mbedOS RP2040 2.0.0
      • Build with -g3 -ggdb
      • Firmware: J-Link EDU Mini V1 compiled Feb 18 2021 11:25:23
      • Hardware: V1.00
      • JLink 7.20
      • Ozone 3.22e
    • New
      We are not aware of such an issue.
      You can find an example blinky project for the RP2040 here:
      wiki.segger.com/Raspberry_Pi_Pico#Example_Projects
      It should be working out of the box for Ozone / Embedded Studio.
      Could you please give that one a try?
