My environment:
SES 5.42 Build 2021031901.45616
MacOS 11.2.3
Solution contains 1 project
Source code written in C
Compiler: gcc
Problem description:
#1 Use the mouse to place the cursor on a symbol which can be a function name, local variable, global variable, MACRO name. Right-click and select "go to definition". This will always take you to the first line of stdarg.h
#2 Now use the mouse to select the full symbol name, then right-click and select "go to symbol name" and it will work as expected.
Method #1 used to work some time ago, maybe a year ago? From my experience this is standard behavior for source code editors. I would like to report this as a bug.
-Mike
MacOS 11.2.3
Compiler: gcc
-Mike
