[ABANDONED] Cannot flash new STM32G030K6 on new design, but J-link will connect.
  • [ABANDONED] Cannot flash new STM32G030K6 on new design, but J-link will connect.
    I have checked that the MCU is powered, and that the reset pin is not triggered.
    Debug Log:
    Fri Apr 16, 2021 10:46:36: Device "STM32G030K6" selected.
    Fri Apr 16, 2021 10:46:36: DLL version: V7.0 , compiled Apr 8 2021 14:30:05
    Fri Apr 16, 2021 10:46:36: Firmware: J-Link V10 compiled Nov 12 2020 10:06:35
    Fri Apr 16, 2021 10:46:36: Selecting SWD as current target interface.
    Fri Apr 16, 2021 10:46:36: JTAG speed is initially set to: 1000 kHz
    Fri Apr 16, 2021 10:46:36: Found SW-DP with ID 0x0BC11477
    Fri Apr 16, 2021 10:46:36: DPIDR: 0x0BC11477
    Fri Apr 16, 2021 10:46:36: Scanning AP map to find all available APs
    Fri Apr 16, 2021 10:46:36: AP[1]: Stopped AP scan as end of AP map has been reached
    Fri Apr 16, 2021 10:46:36: AP[0]: AHB-AP (IDR: 0x04770031)
    Fri Apr 16, 2021 10:46:36: Iterating through AP map to find AHB-AP to use
    Fri Apr 16, 2021 10:46:36: AP[0]: Core found
    Fri Apr 16, 2021 10:46:36: AP[0]: AHB-AP ROM base: 0xF0000000
    Fri Apr 16, 2021 10:46:36: CPUID register: 0x410CC601. Implementer code: 0x41 (ARM)
    Fri Apr 16, 2021 10:46:36: Found Cortex-M0 r0p1, Little endian.
    Fri Apr 16, 2021 10:46:36: FPUnit: 4 code (BP) slots and 0 literal slots
    Fri Apr 16, 2021 10:46:36: CoreSight components:
    Fri Apr 16, 2021 10:46:36: ROMTbl[0] @ F0000000
    Fri Apr 16, 2021 10:46:36: ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C0 ROM Table
    Fri Apr 16, 2021 10:46:36: ROMTbl[1] @ E00FF000
    Fri Apr 16, 2021 10:46:36: ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB008 SCS
    Fri Apr 16, 2021 10:46:36: ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 000BB00A DWT
    Fri Apr 16, 2021 10:46:36: ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 000BB00B FPB
    Fri Apr 16, 2021 10:46:36: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Fri Apr 16, 2021 10:46:36: Reset: Reset device via AIRCR.SYSRESETREQ.
    Fri Apr 16, 2021 10:46:36: Reset: SYSRESETREQ has confused core.
    Fri Apr 16, 2021 10:46:36: Failed to power up DAP
    Fri Apr 16, 2021 10:46:36: Reset: Using fallback: Reset pin.
    Fri Apr 16, 2021 10:46:36: Reset: Reset device via reset pin
    Fri Apr 16, 2021 10:46:36: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    Fri Apr 16, 2021 10:46:36: Reset: Reconnecting and manually halting CPU.
    Fri Apr 16, 2021 10:46:37: CPU could not be halted
    Fri Apr 16, 2021 10:46:37: Reset: Core did not halt after reset, trying to disable WDT.
    Fri Apr 16, 2021 10:46:37: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Fri Apr 16, 2021 10:46:37: Reset: Reset device via reset pin
    Fri Apr 16, 2021 10:46:37: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    Fri Apr 16, 2021 10:46:37: Reset: Reconnecting and manually halting CPU.
    Fri Apr 16, 2021 10:46:37: Failed to power up DAP
    Fri Apr 16, 2021 10:46:37: Reset: Failed. Toggling reset pin and trying reset strategy again.
    Fri Apr 16, 2021 10:46:37: Reset: Reset device via AIRCR.SYSRESETREQ.
    Fri Apr 16, 2021 10:46:37: Reset: SYSRESETREQ has confused core.
    Fri Apr 16, 2021 10:46:38: Failed to power up DAP
    Fri Apr 16, 2021 10:46:38: Reset: Using fallback: Reset pin.
    Fri Apr 16, 2021 10:46:38: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Fri Apr 16, 2021 10:46:38: Reset: Reset device via reset pin
    Fri Apr 16, 2021 10:46:38: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
    Fri Apr 16, 2021 10:46:38: Reset: Reconnecting and manually halting CPU.
    Fri Apr 16, 2021 10:46:38: CPU could not be halted
    Fri Apr 16, 2021 10:46:38: Reset: Core did not halt after reset, trying to disable WDT.
    Fri Apr 16, 2021 10:46:39: Failed to power up DAP
    Fri Apr 16, 2021 10:46:39: CPU could not be halted
    Fri Apr 16, 2021 10:46:39: Warning: Failed to halt CPU.
    Fri Apr 16, 2021 10:46:39: Hardware reset with strategy 0 was performed
    Fri Apr 16, 2021 10:46:39: Initial reset was performed
    Fri Apr 16, 2021 10:46:51: Unloaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 8.4_2\arm\config\flashloader\ST\FlashSTM32G0xxx.mac
    Fri Apr 16, 2021 10:46:52: IAR Embedded Workbench 8.50.9
    Anyone have any ideas?
    We are not aware of any issue with the STM32G0 devices.
    According to the information of the log file, the J-Link is not able to connect to the device.
    Did you make sure that the reset pin is connected on your hardware?Did this work on the same hardware before?
    Does this issue also appear when connecting to the device via J-Link Commander (JLink.exe)?
    Do you use custom hardware or an evaluation board? In the latter case which one?
    If custom hardware, do you experience the same problem on an evaluation board?
