[SOLVED] Using Ozone trace features with J-Link flashed on ST-Link
  • [SOLVED] Using Ozone trace features with J-Link flashed on ST-Link
    Greetings everyone,
    I am wondering if it is possible to use Ozones trace features (timeline, code coverage...) with a reflashed ST-Link to a J-Link.
    In my example, I am using a nucleo-F767ZI board from ST. The on-board ST-Link has been reflashed. Everything works fine in Ozone
    except from the trace features. The instruction trace always says "Instruction trace disabled". As I read in this forum, SWO is not enough to
    use this trace. For that I need trace pins or trace buffer. Unfortunately, the trace pins of the F767 are not connected to the onboard ST-Link.
    My question is, when using an external, reflashed ST-Link and connecting to the corresponding 5 trace pins, is the reflashed J-Link firmware capable
    of using the trace pins or is this only possible with a J-Trace Pro. In addition higher boards like the STM32H7 series feature ETF to be used as trace buffer.
    In that case, can I use a reflashed ST-Link for tracing via buffer?
    With best regards
    A reflashed ST-Link has only capabilities for tracing via trace buffer.
    You can find an example project for the H7 buffer trace here:
    wiki.segger.com/STM32H7#Tracing_on_ST_STM32H743
    Pin tracing will never work as the ST-Links are simply way to slow and have no dedicated hardware to sample the trace pins with the required high speeds.
    For pin tracing a J-Trace Pro is required:
    segger.com/products/debug-probes/j-trace/
