SystemView could not be started
    • SystemView could not be started
      I am using Ubuntu LTS 20.04 with KDE neon.
      I installed SystemView and it would find the libqtcore.so.4 and libqtgui.so.4.
      I then copied them over from ozone install and now I have this issue when I fire SystemView.
      SystemView: symbol lookup error: SystemView: undefined symbol: _ZN12QApplication13setMainWidgetEP7QWidget
      I looked at the thread here:
      [SOLVED] Systemview-Installation fails on Linux
      but I did not find a solution in the end.
      Is there a solution to this problem?
      AQ
    • New
      Could you please try to install the latest version of SystemView?
      The required libs should be part of the package since V3.12.
      You can find the latest version here:
      segger.com/downloads/jlink#SystemView
