Wrong source file opens
    • Wrong source file opens
      Hello! Ozone 3.22.5 misbehaves if project has source files with similar names in different folders: for example, if a project has many "main.c" files in several folders. In Functions window, when I double-click on a function which located in a source file with unique name, it opens correct source file. But if I doubleclick on a function defined in one of "main.c" files, it opens another "main.c" file. In a similar way, I cannot set a breakpoint on a line in opened "main.c" file. Breakpoint is set instead in another "main.c" file. The only way to set a breakpoint in a correct place is to open disassembly and set a beakpoint there.
      Ozone 2.30 does not have this disease, it works correctly in described cases.
      Thanks!
      Michael
    • I'm experiencing exactly this issue myself with 3.22a - my application uses two independant tcp/ip stacks, so there are several duplicated functions/filenames (e.g udp.c, route.c, etc) which results in Ozone taking me to the wrong file when selecting a function which exists in two such files.
      I've resorted to renaming the offending source files so that Ozone doesn't get confused, but was hoping there'd be a better way- Fingers crossed this'll get addressed....
      David
    • New
      Hi Michael,
      Hi David,
      Could you please provide us with a sample project (including .elf-file) this issue is reproducible with?
      Ideally via our Support Ticket System (link below this post, in my signature).
      Please do also refer to this forum post in it (link).
