[SOLVED] JTAG_TRST
  • [SOLVED] JTAG_TRST
    Hi
    I need some help regarding the JTAG_TRST signal.
    I would like to know if the signal is used during programming, as I understand is the pin mostly used during debugging but can can't find anywhere it says it isn't used during programming.
    By programming I mean the segger function "#auto" and by "used" I mean is the signal pull low by the segger flasher ATE during programming?
    I hope you understand my question.
    Kind regards,
    Jakob
  • Hi Jakob,
    There are 2 signals that sound very similar:
    nRST
    This is the reset pin of the MCU.
    This signal is used during programming.
    nTRST
    Test-logic-reset. Nowadays, most MCus do not even provide this signal. It is not really used during programming. So you can usually safely leave out this signal.
