Error in programming SAMD51N19A => Failed to prepare RAMCode using RAM
    • Error in programming SAMD51N19A => Failed to prepare RAMCode using RAM
      for a faster programming in developing I am writing a script resp. batch file, which calls the corresponding functions/commands of J-link in the CMD window.
      I have J-Flash software V.6.98c installed and I use a J-LINK plus
      The controller I use is a SAMD51N19A, there is no external flash or ram connected to it.
      With this skript I do
      -resetting the fuse bits
      -erasing the device from 0x00000 to 0x7FFFF
      then programming
      -setting the fuse bits
      When I do this, i get the error
      "Error: failed to prepare RAMCode using RAM
      Error while determining flash info (Bank @ 0x04000000)
      ERROR: Erase retunred with error code - 1
      The error also comes up when I try to erase the "whole" RAM, resp. I dont use the erase with the range indication.
      If I do the script without the erase command, it works. But I need to erase it first (I guess this should be done...)
      Anyway, the error also comes up, when I use the j-flash - software itself in "Target => Manual Programming => Erase Chip"
      I read a lot in this forum of people having similar problems. But I could not figure out any solution that would work for my problem.
      Has anybody an idea how to eliminate this error?
      Here is a part of my bat-file:
      echo connect > script.jlink
      echo r >> script.jlink
      echo w4 0x00804000 0xFE9A9235 >> script.jlink
      echo w4 0x00804004 0xAEECFF80 >> script.jlink
      echo erase [0x000000, 0x7FFFF]>> script.jlink
      echo loadfile "%hexfile%" >> script.jlink
      echo w4 0x00804000 0xEE9A9234 >> script.jlink
      echo g >> script.jlink
      echo q >> script.jlink
      :FLASH
      jlink.exe -device ATSAMD51N19 -if SWD -speed 4000 -CommanderScript script.jlink -autoconnect 1 -ExitOnError 0
      IF %errorlevel% == 0 GOTO PASS
      IF %errorlevel% NEQ 0 GOTO ERROR
      Could you provide a J-Link log of the failing session?
      Does this issue appear with any image programmed or just this specific one?
      This appears with all of the images I have.
      Here's a log of the failing session:
      SEGGER J-Link Commander V6.98c (Compiled Mar 16 2021 12:20:44)
      DLL version V6.98e, compiled Mar 29 2021 14:18:39
      J-Link Commander will now exit on Error
      J-Link Command File read successfully.
      Processing script file...
      J-Link connection not established yet but required for command.
      Firmware: J-Link V10 compiled Feb 4 2021 12:58:41
      Hardware version: V10.10
      S/N: 600116830
      VTref=3.315V
      Device "ATSAMD51N19" selected.
      Connecting to target via SWD
      InitTarget() start
      InitTarget()
      InitTarget() end
      InitTarget() end
      DPIDR: 0x2BA01477
      AP[2]: Stopped AP scan as end of AP map seems to be reached
      AP[1]: AHB-AP (IDR: 0x74770001)
      AP[0]: Core found
      AP[0]: AHB-AP ROM base: 0x41003000
      CoreSight components:
      ROMTbl[0] @ 41003000
      ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C4 ROM Table
      ROMTbl[1] @ E00FF000
      ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
      ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
      ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
      ROMTbl[1][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
      ROMTbl[1][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
      ROMTbl[1][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
      ROMTbl[1][6]: E0042000, CID: B105900D, PID: 003BB907 ETB
      Cortex-M4 identified.
      Reset delay: 0 ms
      Writing FE9A9235 -> 00804000
      Writing AEECFF80 -> 00804004
      Without any give address range, Erase Chip will be executed
      Erasing device...
      J-Link: Flash download: Total time needed: 2.777s (Prepare: 0.102s, Compare: 0.000s, Erase: 2.672s, Program: 0.000s, Verify: 0.000s, Restore: 0.003s)
      J-Link: Flash download: Total time needed: 0.068s (Prepare: 0.020s, Compare: 0.000s, Erase: 0.045s, Program: 0.000s, Verify: 0.000s, Restore: 0.003s)
      ****** Error: Failed to prepare RAMCode using RAM
      ERROR: Erase returned with error code -1.
      Script processing completed.
      ERROR
