Subsequent Connections to RP2040 Fail
    • Subsequent Connections to RP2040 Fail
      Hi all, I'm using a J-link Mini Edu to debug firmware on a Raspberry Pi Pico board. If I plug in my J-link, start the GDB server, and load my .ELF file, it will work fine first time. However, if I close the GDB server, rebuild my project, and try to start the GDB server again, it will fail to connect to the RP2040, giving a communication error. If I unplug the USB cable on the J-link and plug it back in again, I am able to connect to the board again. It appears that a full power-down resets something, allowing me to connect again.
      Is there some sort of command I should issue when starting the GDB server or just before closing it to force a reset of the hardware so I don't have to keep unplugging and replugging my USB cable?
    • We also stumbled across this.
      It is currently under investigation.
      We will update this thread, once it is solved.
      It seems to have something to do with SWD multi-drop. Maybe a misbehavior inside the J-Link firmware...
      Keep you posted
    • I am using Ozone with JLInk Edu mini and RP2040 B0.
      Ozone upload is working, but debugging fails after upload. Target reset doesn't help. But disconnect-reconnect JLink helps, after that "attach to running program" is working. It's probably the same subsequent connection problem.
      J_Flash lite: better to use .hex, because the start address is not zero for .bin.
      After erase chip, a target reset required before flashing.
      It's a bit uncomfortable, that no power for the target from the mini, and most of my targets has no standard swi connector. So I put a 3.3V LDO and the mini to a small 3d printed box with 2.54mm pin headers. The yellow jumper connects the 3.3V to VTRef.
      As Alex already pointed out:
      This issue is known to us and we are currently working on it.
      Regarding the power supply:
      If you want a non-commercial J-Link with target power support, we would recommend the J-Link EDU:
      segger.com/products/debug-probes/j-link/models/j-link-edu/
      It comes with a 5V pin, and other beneficial features.
      A comparison between our models can be found here:
      segger.com/products/debug-prob…erview/#hardware-features
      Even though it is a little bit more expensive then the EDU mini,
      it should still be in an affordable price range for private users / students.
    • This issue is still present in 7.20. Since there was no firmware update for the probe I suspected that was the case, but just confirmed it locally. Bumping this in case the issue has fallen off the radar.
