[SOLVED] Can't debug code link to RAM with Jlink on imxrt1064
  • [SOLVED] Can't debug code link to RAM with Jlink on imxrt1064
    I am using the rt1064 on a custom board (SDK version 2.9.1) and debugging using MCUXpresso IDE v11.3.0. I would like to link application to RAM but I'm not able to debug with Segger JLink Ultra+ probe.
    To accomplish this, I did the following:
    • Set up SRAM_ITC to be the first RAM region listed in the memory configuration table (this region is large enough to hold our application).
    • Set up the SRAM_DTC to placed the heap and stack there.
    • Checked the "Link application to RAM" checkbox in the managed linker script.
    • In the Startup tab of the 'Edit Launch Configuration' dialog, set "monitor reset 6" to "Initialization Commands".
    • Remove XIP from SDK setup.
    • Remove XIP preprocessor defines from project settings.
    When I try to download this through the debugger, the behavior is not stable. The first time I get this:
    Display Spoiler
    [01-3-2021 10:50:29] Executing Server: "C:\Program Files (x86)\SEGGER\JLink\JLinkGDBServerCL.exe" -nosilent -swoport 2332 -select USB=504505558 -telnetport 2333 -endian little -ir -speed auto -rtos GDBServer/RTOSPlugin_FreeRTOS -port 2331 -vd -device MIMXRT1064xxx6A -if SWD -halt -reportuseraction
    SEGGER J-Link GDB Server V6.88c Command Line Version
    JLinkARM.dll V6.88c (DLL compiled Dec 4 2020 18:05:56)
    Command line: -nosilent -swoport 2332 -select USB=504505558 -telnetport 2333 -endian little -ir -speed auto -rtos GDBServer/RTOSPlugin_FreeRTOS -port 2331 -vd -device MIMXRT1064xxx6A -if SWD -halt -reportuseraction
    GDBInit file: none
    Terminal I/O port: 2333
    Generate logfile: off
    Verify download: on
    Init regs on start: on
    Silent mode: off
    Single run mode: off
    J-Link Host interface: USB
    J-Link script: none
    J-Link settings file: none
    Target device: MIMXRT1064xxx6A
    Target interface: SWD
    Target interface speed: auto
    Target endian: little
    Connecting to J-Link...
    J-Link is connected.
    Device "MIMXRT1064XXX6A" selected.
    Firmware: J-Link Ultra V4 compiled Nov 12 2020 10:07:39
    Hardware: V4.00
    S/N: 504505558
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    Checking target voltage...
    Target voltage: 3.29 V
    Listening on TCP/IP port 2331
    Connecting to target...
    InitTarget() start
    InitTarget()
    _TargetHalt: CPU halted
    InitTarget() end
    Found SW-DP with ID 0x0BD11477
    DPIDR: 0x0BD11477
    AP[0]: AHB-AP (IDR: 0x04770041)
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0xE00FD000
    CPUID register: 0x411FC271. Implementer code: 0x41 (ARM)
    Found Cortex-M7 r1p1, Little endian.
    FPUnit: 8 code (BP) slots and 0 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FD000
    ROMTbl[0][0]: E00FE000, CID: B105100D, PID: 000BB4C8 ROM Table
    ROMTbl[1] @ E00FE000
    ROMTbl[1][0]: E00FF000, CID: B105100D, PID: 000BB4C7 ROM Table
    ROMTbl[2] @ E00FF000
    ROMTbl[2][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[2][1]: E0001000, CID: B105E00D, PID: 000BB002 DWT
    ROMTbl[2][2]: E0002000, CID: B105E00D, PID: 000BB00E FPB-M7
    ROMTbl[2][3]: E0000000, CID: B105E00D, PID: 000BB001 ITM
    ROMTbl[1][1]: E0041000, CID: B105900D, PID: 001BB975 ETM-M7
    ROMTbl[1][2]: E0042000, CID: B105900D, PID: 004BB906 CTI
    ROMTbl[0][1]: E0040000, CID: B105900D, PID: 000BB9A9 TPIU-M7
    ROMTbl[0][2]: E0043000, CID: B105F00D, PID: 001BB101 TSG
    Cache: Separate I- and D-cache.
    I-Cache L1: 32 KB, 512 Sets, 32 Bytes/Line, 2-Way
    D-Cache L1: 32 KB, 256 Sets, 32 Bytes/Line, 4-Way
    InitTarget() start
    InitTarget()
    InitTarget() end
    DPIDR: 0x0BD11477
    AP map detection skipped. Manually configured AP map found.
    AP[0]: AHB-AP (IDR: Not set)
    AP[0]: Core found
    Connected to target
    Reading all registers
    Read 4 bytes @ address 0x00000000 (Data = 0x00000000)
    GDB closed TCP/IP connection (Socket 1056)
    GDB closed TCP/IP connection (Socket 1076)
    Server has been shut down.
    But the second time I try to debug I get this:
    Display Spoiler
    C:
    xp\MCUXpressoIDE_11.3.0_5222\ide\plugins\com.nxp.mcuxpresso.tools.win32_11.3.0.202008311133 oolsinrm-none-eabi-gdb.exe: warning: Couldn't determine a path for the index cache directory.
    GNU gdb (GNU Arm Embedded Toolchain 9-2020-q2-update) 8.3.1.20191211-git
    Copyright (C) 2019 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later <gnu.org/licenses/gpl.html>
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    Type "show copying" and "show warranty" for details.
    This GDB was configured as "--host=i686-w64-mingw32 --target=arm-none-eabi".
    Type "show configuration" for configuration details.
    For bug reporting instructions, please see:
    <gnu.org/software/gdb/bugs/>.
    Find the GDB manual and other documentation resources online at:
    <gnu.org/software/gdb/documentation/>.
    For help, type "help".
    Type "apropos word" to search for commands related to "word".
    I use the default script.jlink file. However, I've modify the address from 0x70000000 (external QSPI flash included in imxrt1064 device) to 0x00000000 (ITC RAM).
    The question is, am I missing any settings? Do you have a script example for RAM debugging with imxrt1064 microcontroller?
    Hugo
    Note: Attached file "JLink Debug.txt" was renamed so I can attach it to this post. Its original name was "JLink Debug.launch"
    • script.jlink
      (82 Byte, downloaded 389 times, last: )
    • JLink Debug.txt
      (7.34 kB, downloaded 360 times, last: )
    This would be a question for the NXP support and not SEGGER, as the issue is setup related, and not J-Link related.
    It seems like you download the application behind the back of the MCUXpresso IDE.
    There is no way for it to know where the application actually is placed, and it apparently assumes it to be at a certain location.
    I quickly searched for this topic on google and found a post that might help you:
    community.nxp.com/t5/MCUXpress…ogram-from-RAM/m-p/735076
