[DUPLICATE] RP2040 QSPI flash programming support
  • [DUPLICATE] RP2040 QSPI flash programming support
    I have successfully used the latest version of JLink GDB Server (v6.96) to debug the RP2040 on a RPi Pico board. Thanks for the quick support for this! However, I was not able to successfully program the internal QSPI flash over JLink. Is that not supported yet on JLink, or am I likely doing something incorrectly?
    Thanks!
  • Example of QSPI not programming correctly
    Here is an example output with the GDB `load` command failing to verify (verify download option enabled):
    GDB client side:
    (gdb) load
    Loading section .boot2, size 0x100 lma 0x10000000
    Loading section .text, size 0x7028 lma 0x10000100
    Loading section .rodata, size 0x1370 lma 0x10007128
    Loading section .binary_info, size 0x20 lma 0x10008498
    Loading section .data, size 0xb14 lma 0x100084b8
    Start address 0x10000104, load size 36812
    Transfer rate: 115 KB/sec, 2831 bytes/write.
    JLink GDB Server side:
    Reading all registers
    Read 4 bytes @ address 0x10000DE4 (Data = 0x4B089A05)
    Downloading 256 bytes @ address 0x10000000 - Verified OK
    Downloading 4096 bytes @ address 0x10000100 - Verify failed
    Downloading 4096 bytes @ address 0x10001100 - Verify failed
    Downloading 4096 bytes @ address 0x10002100 - Verify failed
    Downloading 4096 bytes @ address 0x10003100 - Verify failed
    Downloading 4096 bytes @ address 0x10004100 - Verify failed
    Downloading 4096 bytes @ address 0x10005100 - Verify failed
    Downloading 4096 bytes @ address 0x10006100 - Verify failed
    Downloading 40 bytes @ address 0x10007100 - Verified OK
    Downloading 4096 bytes @ address 0x10007128 - Verify failed
    Downloading 880 bytes @ address 0x10008128 - Verify failed
    Downloading 32 bytes @ address 0x10008498 - Verified OK
    Downloading 2836 bytes @ address 0x100084B8 - Verify failed
    Writing register (PC = 0x10000104)
    Read 4 bytes @ address 0x10000104 (Data = 0x49272000)
    This is a duplicate of:
    RP2040 Support
    Please refer to the information provided in this thread.
