[SOLVED] Tracing over SWD pins?
  • [SOLVED] Tracing over SWD pins?
    I think I know the answer from the documentation I've read on the J-Trace but I want to be sure:
    Is it possible to do instruction tracing over just the minimum SWD connection? (SWDIO and SWDCLK). I have a project that's extremely limited on I/O and the trace pins and SWO pins are used for other purposes. Or do you absolutely have to have the trace pins (TRx and TCLK) in order to do instruction tracing?
    For a reliable instruction trace, you need (besides SWCLK and SWDIO) also TCLK and TDATA 0-3 (TDATA0 may be sufficient for slower core speeds).
    The trace pins are there for a reason...
    Theoretically, you can also output the ETM (instruction trace) data over the SWO pin but it is easily overloaded with that data. SWO was mainly designed for printf-like output.
