[SOLVED] multiple project with different configurations in a single solution
  • [SOLVED] multiple project with different configurations in a single solution
    It is possible to have a single solution which contains multiple projects, each with its own build configuration?
    I would like to combine an application project with a boot loader project in a single solution. However this means you must be able to all the build parameters for each project independently.
    TIA
  • Hello TIA,
    Yes this is possible.
    To try it out easiest would be to simply create a new project in a new solution.
    Then create a second project but select "Add the project to the current solution".
    How private and public build configs can inherit from each other is explained here:
    wiki.segger.com/Embedded_Studi…blic_Build_Configurations
    studio.segger.com/ide_project_…s_and_property_values.htm
  • Just to be clear,
    This is a Nordic solution. Each project in the solution will require its own flash_placement.xml, sdk_config.h, compiler options, build targets (debug and release).... Almost no inheritance.
    Is it a matter of rearranging the XML everything is moved into the "project" tag?
    Yes that works in the same fashion. The inheritance is just an additional feature that helps to create many configs that are similar quickly.
    But you can of course specify multiple projects in one solution where each has its own unique set of settings.
  • I think I have the same problem:
    I have two projects in one solution. Both projects should have their own build configurations. Let's say project1 has build configurations buildconfig1 and buildconfig2 based on commonbuildconfig1, and project2 has build configurations buildconfig3 and buildconfig4 based on commonbuildconfig2.
    How can this be accomplished?
    It seems the build configurations are always on a solution level somehow. For example, if the selected build configuration (in the UI) is buildconfig1, both project1 and project2 will be built with build configuration buildconfig1, although this build configuration is only relevant for project1.
    bds
  • Hello bds,
    Your issue seems to be different
    See above for links explaining how private/public configs work.
    To not get off topic this thread will be closed now.
