[SOLVED] J-Link dual core debugging - cross core break
  • [SOLVED] J-Link dual core debugging - cross core break
    Project si about a dual core STM32H745, we are currently using a DISCO board.
    By using the onboard STLINK debugger there is the option to use a so called Break Cross Trigger Matrix Configuration - when reaching a breakpoint on one core the other core can be stopped as well.
    With the J-Trace debugger we are running 2 instances of SystemWorkbench (with installed plugin "GDB SEGGER J-Link Debugging") , each instance is debugging one core. Is it possible to use this cross core break feature also with J-Trace (J-Link)?
    Thank you!
    This feature is not yet available.
    It is planned for sometime later this year.
    In this case, we will close this thread now.
