Reading Serial port with EMStudio
    • Reading Serial port with EMStudio
      Hello All
      In 2020 I have managed to read the serial port with the ETC Compute sensor board and JLInk EDU mini via the terminal emulator on MAC OSX Sierra just fine.
      The new SDK requires from me to move on to Linux and this is what I have done, so now I am on Ubuntu 20.04 and installed the new SDK including the emStudio 5.34 ... Compilation and upload works very good, however, I cannot sort out the serial port, for example, although I have enabled the terminal emulator in emStudio according to the e.g. /dev/ttyUSB0 , which I found via the terminal , somehow I do not get the readings?
      Before that I had an issue with "error permission (13)" so I have enabled to run the emStudio as sudo... which was strongly unadvisedly by my administrator... anyway, I can now "select, use" the serial port with the emStudio and its terminal emulator, but I do no get any readings?
      Please let me know how to approach this problem?
      BEST.
      The post was edited 1 time, last by MUETA: Solved! ().
