[SOLVED] Segger 5.34 displays RAM use erroneously
  • [SOLVED] Segger 5.34 displays RAM use erroneously
    The Segger 5.34 IDE displays identical project RAM use oddly: .stack_process uses 64k, stack 3.1%. The project file sets stack_process =0.
    The program still works as it does in 5.32, where stack is 3.1%, no .stack_process
    Borje
    We are aware of this issue and it will be fixed in the next release.
    It is only a display issue and has no impact on your target application.
