[SOLVED] Questions about Export Data Graphs Feature
  • [SOLVED] Questions about Export Data Graphs Feature
    yesterday we wanted to export a timeline (or rather its values) as CSV data for further analysis.
    We collected some data for about a minute and then used File -> Expoert -> Data Graphs... to export it.
    Against our expectation this only exported one point in time and not tho whole graph.
    Source Code: Ozone_Data_Sampling_210121.csv
    1. Level,Expression,Type,Value,Min,Max,Average,# Changes
    2. 0,mcu_var_batdivVoltage,unsigned short,47?312,0,48?341,47?299,37?956
    3. 0,stm_state,enum stm_state_t,4,0,4,4,1
    Is our expectation faulty here? I tried to check the Ozone manual but could not find a definitive answer to this there.
    So the question is:
    - Is there a way to export the whole timeline for further analysis in e.g. Excel?
    Also:
    - What about the question marks in the numbers? Is this the thousands separator? I guess then it probably should not go into the CSV export?
    Cheers
    Ozone will always only export the context of the current window/tab.
    You probably exported the "Setup" tab in the data sampling window which will only export the statistics.
    If you want the raw data you need to export the "Samples" tab.
    There you will find the complete raw data.
    We will revisit the Ozone manual and see if it can be improved to explain this better.
    thanks for the hint. It works then. :)
    It is kind of hard to see this difference when using the File -> Export.. menu. Maybe there could be a differentiation as well.
    Also the file names created from the two tabs are very similar
    [img]data:image/png;base64,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[/img]
    Maybe this could be improved by naming them Ozone_DataSampling_Setup and Ozone_DataSampling_Samples.
    Anyway, thanks four your help. :)
    Cheers
    We will discuss internally and see where the export GUI can be improved so it works more intuitively.
