[SOLVED] How to use ImportSVD in a Memory Map file
  • [SOLVED] How to use ImportSVD in a Memory Map file
    In the Memory Map file format documentation it mentions the ImportSVD tag. This would be useful for me, but I cannot figure out where to use it.
    Can anyone point to an example of how to use it? I don't know where in the XML file it should be.
    You can simply call it as documented within the root tags of your memory map.
    There is one typo though in the documentation, should be /> at the end.
    Could you elaborate how you plan to use this and what your benefit you expect from it?
    It is a legacy option kept for compatibility but should not be used in new setups if possible.
  • I have the same question.
    If the SVD file can be used in Embedded Studio, more old chip projects move to the IDE will be possiable.
    Or, Segger provide a convert tool in IDE to translate SVD file to new memory map file is another option.
    This appears to be a different question. This thread is about importing a svd file to the memory map.
    Using a svd file to access registers you can do that with Embedded Studio.
    Simply set the svd file in project options under "Register Definition File".
