Issues with syntax-highlighting
    • Issues with syntax-highlighting
      Hello Segger-Team,
      I found some issues with syntax-highlighting in Embedded Studio, maybe you could solve those:
      • Ampersand in comments leads to a highlighted line:
      • If you enable the option “visible whitespace”, XML Files are not rendered correctly. For example, the project File:
        vs.
      • When the options “visible whitespace” and “Highlight All Selected Text” are enabled, and a space is selected, then all tabs are highlighted while no other space is highlighted:
        Selecting a tab highlight nothing.
      • Syntax-Highlighting in assembler Files ignores @ as start of comment, for example in the uCOS-II sources
        C-Style-commends are shown as expected
      • One last thing, could you highlight the types from stdint like the native types.
      Best Regards
      1: Was not reproducible for me. Could you give the latest Embedded Studio a try? Do you still see this behaviour? If yes, could you post a code/comment snippet in the forum as a reproducer?
      2: Is reproducible and will be improved.
      3: Is not reproducible for me. Could you provide an examplefile with reproduction steps?
      4: Is reproducible and will be improved.
    • Hello Nino,
      find attached a simple project.
      Open the File fsl_flexcan.h and scroll to line 675 to find an example for the ampersand issue.
      Regarding issue 3, enable the two options
      • visible whitespace
        Edit --> Others --> Visible Whitspace
      • Highlight All Selected Text
        Tools --> Options --> Text Editor --> Highlight All Selected Text
      Open the file main.c and select a space character, for example the one after the keyword ‘for‘. You should see the behaviour from my screenshot.
      I have one more for you:
      The detection of invalid code is not working correctly. Check the file fsl_device_register.h in my demo project. I would expect, that the line 24 would be shown normal not greyed out.
      Is it possible to highlight types from stdint.h?
      Hope this helps
      • Example.7z
        (300.14 kB, downloaded 26 times, last: )
      Thank you for providing the example project.
      Yes its reproducible and will be improved.
      Again reproducible. Will be improved.
      Looks incorrect. I added it to our bugtracker and we will investigate further.
      Currently not, but it is already on our wishlist.
    • Hello Nino,
      thanks for the feedback.
      Bye the way, Comments in XML-Files are not colored properly. I would expect that the angle bracket which enframe comments are also colored like the rest of the comment.
      We will add this to the improvements list.
      Thank you for the reproducer.
      We will investigate this and fix it accordingly.
