*Apparent BUG, ver: 3.22a* Variables out of scope when should not be!
    • *Apparent BUG, ver: 3.22a* Variables out of scope when should not be!
      Here is a snippet of my code. currString and currDot are out of scope in the watch window and mouse over will not show a variable. NOTE: This is C++.
      STM32F4, and here is the gcc --version output
      1. arm-none-eabi-gcc (GNU Arm Embedded Toolchain 9-2020-q2-update) 9.3.1 20200408 (release)
      2. Copyright (C) 2019 Free Software Foundation, Inc.
      3. This is free software; see the source for copying conditions. There is NO
      4. warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
      and
      1. CFLAGS += -g -gdwarf-2
      1. /* Infinite loop */
      2. while (1) {
      3. int currLedString;
      4. for (currLedString = 0; currLedString < NoLedStrings; currLedString++) {
      5. struct ledString *currString = &ledStrings[currLedString];
      6. if (currString->changes) {
      7. currString->changes = 0;
      8. if (currString->mode == LedModeOff) {
      9. memset(&leds, 0, sizeof(leds));
      10. } else {
      11. // All other modes have a back ground color
      12. currString->backColor.parts.lead = 0xFF;
      13. volatile int ctr;
      14. for (ctr = 0; ctr <= MAX_LEDS; ctr++) { leds.led[ctr].raw = currString->backColor.raw; }
      15. for (ctr = 0; ctr < MaxLedDots; ctr++) {
      16. struct ledDot *currDot = &currString->dots[ctr];
      17. if (currDot->size > 0) {
      18. int pos;
      19. asm("nop");
      20. for (pos = (1 + currDot->pos - (currDot->size - 1));
      21. pos < (1 + currDot->pos + (currDot->size - 1)); pos++) {
      22. asm("nop");
      23. int delta = pos - currDot->pos; // How far from the center of the dot
      24. if (delta < 0)
      25. delta *= -1;
      26. delta++;
      Could you provide a simple reproducer that could run on an STM32F4 eval board?
      The compiled elf file and the source file in question should be sufficient.
