[SOLVED] Timeline cursor numbers hidden, when range is set
  • [SOLVED] Timeline cursor numbers hidden, when range is set
    when I set a Y range in the timeline view, a scrollbar appears on the right. When I move the cursor to the right to see the newest values, the numbers that are shown right of the cursor are hidden behind the scrollbar.
    Can you confirm this?
    Cheers
    No sure what you mean. Could you provide a video showing the behaviour?
    here is a video showing the behaviour.
    Notice the number "1" label in the timeline view.
    At first it is alright, being put to the left of the mouse cursor position when there is not enough space on the right.
    When I then set a Y range, a scrollbar appears. This scrollbar is not included in the calculation of enough space so the "1" label moves almost completely under the scrollbar before being moved to the left.
    The video is made on Debian Linux but the same can be observed on Windows 10.
    Cheers
    Thank you for the video. We were able to reproduce the behaviour and it will be fixed.
