[SOLVED] System View - Could not open J-Link shared library
  • [SOLVED] System View - Could not open J-Link shared library
    similar to the thread: System View - J-Link Library not found
    I cannot load the shared library under Linux!
    On the command line I get the following output when the program is called:"Could not open J-Link shared library.Could not open J-Link shared library."
    I checked the lib dependencies:
    linux-vdso.so.1 (0x00007ffd13585000)
    libQtGui.so.4 => /xyz/SystemView_Linux_V320_x86_64/./libQtGui.so.4 (0x00007f772ea41000)
    libQtCore.so.4 => /xyz/SystemView_Linux_V320_x86_64/./libQtCore.so.4 (0x00007f772e551000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f772e520000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f772e51a000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f772e4f7000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f772e316000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f772e1c5000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f772e1aa000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f772dfb8000)
    libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f772def9000)
    libSM.so.6 => /usr/lib/x86_64-linux-gnu/libSM.so.6 (0x00007f772deee000)
    libICE.so.6 => /usr/lib/x86_64-linux-gnu/libICE.so.6 (0x00007f772ded0000)
    libXrender.so.1 => /usr/lib/x86_64-linux-gnu/libXrender.so.1 (0x00007f772dcc4000)
    libXrandr.so.2 => /usr/lib/x86_64-linux-gnu/libXrandr.so.2 (0x00007f772dcb7000)
    libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3 (0x00007f772dcaf000)
    libXcursor.so.1 => /usr/lib/x86_64-linux-gnu/libXcursor.so.1 (0x00007f772dca2000)
    libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007f772dc5b000)
    libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007f772dc46000)
    libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f772db07000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f772f6f7000)
    libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f772dacf000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f772dab3000)
    libuuid.so.1 => /lib/x86_64-linux-gnu/libuuid.so.1 (0x00007f772daaa000)
    libbsd.so.0 => /usr/lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f772da90000)
    libexpat.so.1 => /lib/x86_64-linux-gnu/libexpat.so.1 (0x00007f772da60000)
    libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f772da36000)
    libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f772da30000)
    libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f772da28000)
    Does anyone have any idea what the problem could be?
    Small note on the side:
    In version v310 the software terminates immediately, but not in v320! Unfortunately, the warning is only issued on the command line, so that you cannot directly see why SystemView cannot find the hardware.
    greetings
    Florian
    Did you follow the Wiki article suggestions for Linux that Johannes posted?
    Is the J-Link software installed on your Linux machine?
    Should the Wiki suggestion not work try to copy the J-Link library from the J-Link folder to the SystemView older.
    yes I read this article.
    Interestingly, the LIB libudev.so does not appear in the dependency list that I have attached!
    I have copied libjaylink.so, libjaylink.so.0, libjaylink.so.0.0.0 into the directory.Interestingly enough, I can program a target with the J-Link from the STM32CubeIDE Studio.
    greetings
    Florian
  • Hello Florian,
    We will consider this thread a solved now.
