[SOLVED] JLINK_CORESIGHT_WriteDP parameter
  • [SOLVED] JLINK_CORESIGHT_WriteDP parameter
    Hello Segger Team,
    I try to understand a JinkScript for the iMXRT685 which comes with the SDK from NXP.
    They call JLINK_CORESIGHT_WriteDP like this:
    1. JLINK_CORESIGHT_WriteDP(2, 0x020000f0);
    According your documentation, the first parameter can be one of
    • JLINK_CORESIGHT_DP_REG_IDCODE
    • JLINK_CORESIGHT_DP_REG_ABORT
    • JLINK_CORESIGHT_DP_REG_CTRL_STAT
    • JLINK_CORESIGHT_DP_REG_SELECT
    • JLINK_CORESIGHT_DP_REG_RDBUF
    • JLINK_CORESIGHT_AP_REG_CTRL
    • JLINK_CORESIGHT_AP_REG_ADDR
    • JLINK_CORESIGHT_AP_REG_DATA
    • JLINK_CORESIGHT_AP_REG_BD0
    • JLINK_CORESIGHT_AP_REG_BD1
    • JLINK_CORESIGHT_AP_REG_BD2
    • JLINK_CORESIGHT_AP_REG_BD3
    • JLINK_CORESIGHT_AP_REG_ROM
    • JLINK_CORESIGHT_AP_REG_IDR
    Which of those constants is related to the Index two?
    Thanks and regards
    Usually, this would be JLINK_CORESIGHT_DP_REG_SELECT.
  • Hello Fabian,
    thank you for your feedback.
    What do you mean with usually? Is this dependent to the used controller?
    NXP is using ‘JLINK_CORESIGHT_WriteDP’ regular with a number instead of the symbolic constants, therefore is it possible to get a full list with the relates indices?
    Thanks, and best regards
    Sorry this was a Typo.
    For DP, RegIndex "2" is always JLINK_CORESIGHT_DP_REG_SELECT.
    RegIndex specifies the index of the DP register.
    The DP registers and the related indexes are documented by ARM.
    Currently you would have to look them up in the ARM documentation.
    I will check internally if we want to add the define values to the documentation.
  • Hello Fabian,
    the Indexes you are using for JLINK_CORESIGHT_WriteDP seems not to be related to the addresses of the registers which you can find in the ARM specification.
    Compare developer.arm.com/documentatio…tation-specific-registers
    The Register Addresses are
    Address
    Read
    Write
    0x00
    IDCODE
    ABORT
    0x04
    CTRL/STAT
    CTRL/STAT
    0x08
    RESEND
    SELECT
    0x0C
    RDBUFF
    N/A
    Therefore, it would be good to have the values in the documentation
    That is why I did not write "Address" but "Index".
    Address / 4 = Address or:
    Index * 0x4 = Address =>
    For Write:
    Index 0 => 0x0 ABORT
    Index 1 => 0x4 CTRL/STAT
    Index 2 => 0x8 SELECT
    Index 3 => N/A
    This is very understandable.
    I am sorry for not being clear enough.
    Do you have any further questions regarding this?
