LIstwheel do not work
    • LIstwheel do not work
      Hi
      I do have a resitive touch xpt2046 and a ssd1963 screen.
      All widgets work fine except the listwheel.
      When i do touch it, it become highlightet in the first row, but it do not move
      listwheel_getpos return zero
      i do use GUI_TOUCH_Exec(); to update
      while (1)
      HAL_Delay(10);
      GUI_TOUCH_Exec();
      GUI_Exec();
      /* USER CODE END WHILE */
      /* USER CODE BEGIN 3 */
      case WM_NOTIFICATION_RELEASED:
      // USER START (Optionally insert code for reacting on notification message)
      hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTWHEEL_0);
      uint16_t position = LISTWHEEL_GetPos(hItem);
      // position = 15 ;
      LISTWHEEL_SetSel(hItem, position);
      // USER END
      break;
      where to look after the issue ...listwheel do not move ...
      best regards
      Hjalmar
      Are the function GUI_X_Delay() and GUI_X_GetTime() are properly implemented?
      Attached is are some examples to be used with FreeRTOS/embOS or without RTOS. For the non-ROTS variant you have to set up a hardware timer wich increments OS_TimeMS every ms.
      EDIT: Forgot the attachment.
      • GUI_X.zip
        (4.48 kB, downloaded 373 times, last: )
