we are debugging our XIP project for IMXRT1020 in EWARM 8.42.2 with Jlink v6.7c (changing to a newer version does not help) at our own hardware.
If we use the project debugger option "Auto" for Breakpoints we can set a breakpoint at a switch (exactly at the switch(....) statement) with 20 cases but we can not single step afterwards. If we try to single step a jlink "Reprogramming flash" window will open and be stuck at Erase 0%, Erasing range 0x60150000.... Compare is at 100%
If we use the breakpoint option "Hardware" everything works as expected. We can set the breakpoint at the switch and single step through it. How many hardware breakpoints are supported at the IMXRT1020?
If we use the breakpoint option "Software" the debugging session won't properly start/run at all.
I have read in Jlink release notes from Jlink v 6.7f "Renesas RX: Software breakpoints in flash did not work. Fixed." Could it be a problem with the IMXRT1020 too?
Kind regards,
Stefan
Kind regards,
Stefan
