Correct use of Debug.Evaluate when writing RTOS-aware plug-in
    • Correct use of Debug.Evaluate when writing RTOS-aware plug-in
      Hi
      I'm writing an Ozone RTOS plugin for MQX.
      Within Ozone's watch window, I can see the structure containing the data of interset, but I don't seem to be able to correctly read this structure within the *.js file
      As far as I can tell, my approach (attached) mirrors the Debug.evaluate example given in UM08025, but I'm getting 'undefined' when attempting to access any structure member following the successful evaluation check.
      What am I missing?
      Many thanks
      D
      Which Ozone version are you using currently? Is it the latest 3.20h?
      If not could you give that a try?
    • Hi Nino
      Release 3.22 does resolve a couple of issues I was seeing, however the cause of this particular issue remains and appears to relate to the casting of the address
      The structure 'kernel_data_struct' has a typedef of KERNEL_DATA_STRUCT_PTR, if I use this i.e.
      var KernelData = Debug.evaluate("*(KERNEL_DATA_STRUCT_PTR)" + 0x60050074c);
      KernelData contains the expected results.
      However, If I use:
      var KernelData = Debug.evaluate("*(struct kernel_data_struct *)" + 0x60050074c);
      i.e. the 'original' data type used in the typedef, attempting to acccess any member data within KernelData results in 'undefined'. So it appears that if there's a typedef for the pointer, you must use that when casting within Debug.evaluate and not the 'original' data type.
      Not sure if this is expected behaviour, but I mention it in case it's helpful.
      David
    • Hello David,
      The whole argument is a string. So you need to put the "" around the complete argument.
