[SOLVED] Using JLink Commander for SAM4E user signature
  • [SOLVED] Using JLink Commander for SAM4E user signature
    I need to program the User Signature Area on SAM4E (store production data, serial number, calibration, etc.)
    I found this thread with a person requesting writing the user signature area on a different SAM4 MCU, but there is no reply and the thread is 3 years old:
    forum.segger.com/index.php/Thr…e-programming-via-J-Link/
    I have written a Flash Loader (ramcode/applet) and included it in JLinkDevices.xml. I can erase the User Signature area using J-Link commander:
    1. J-Link>exec EnableEraseAllFlashBanks
    2. J-Link>erase 0x00C00000 0x00C001FF
    3. Erasing selected range...
    4. J-Link: Flash download: Total time needed: 0.129s (Prepare: 0.018s, Compare: 0.000s, Erase: 0.065s, Program: 0.000s, Ver
    5. ify: 0.000s, Restore: 0.046s)
    6. J-Link: Flash download:
    7. Flash sectors within Range [0x00C00000 - 0x00C001FF] deleted.
    8. Erasing done.
    I can write to the User Signature Area (which includes read/verify):
    1. J-Link>loadfile c:\test\usig_src.bin 0x00C00000
    2. Downloading file [c:\test\usig_src.bin]...
    3. J-Link: Flash download: Bank 1 @ 0x00C00000: 1 range affected (512 bytes)
    4. J-Link: Flash download: Total: 0.211s (Prepare: 0.030s, Compare: 0.052s, Erase: 0.027s, Program: 0.030s, Verify: 0.024s,
    5. Restore: 0.046s)
    6. J-Link: Flash download: Program speed: 17 KB/s
    7. O.K.
    And if I try to program again, the section gets skipped, because it already matches:
    3. J-Link: Flash download: Bank 1 @ 0x00C00000: Skipped. Contents already match
    4. O.K.
    And immediately after programming I can read back the user signature area:
    1. J-Link>savebin c:\test\usig.bin 0x00C00000 0x200
    2. Opening binary file for writing... [c:\test\usig.bin]
    3. Reading 512 bytes from addr 0x00C00000 into file...O.K.
    Unfortunately, if i exit the JLink commander session and start a new one, I cannot read out the user signature area:
    1. J-Link>savebin c:\test\fail.bin 0x00C00000 0x200
    2. Opening binary file for writing... [c:\test\fail.bin]
    3. Reading 512 bytes from addr 0x00C00000 into file...Could not read memory.
    Because the User Signature Area is not memory mapped, I have implemented a native read function. But it seems the ramcode/applet is not loaded or used when calling savebin. :(
    Reading works fine in J-Flash (manual > read-back > range...):
    1. Reading target memory (0x00C00000 - 0x00C001FF) ...
    2. - Start of determining flash info (Bank 1 @ 0x00C00000)
    3. - End of determining flash info
    4. - Flash bank info:
    5. - 1 * 512 bytes @ 0x00C00000
    6. - Start of preparing flash programming
    7. - End of preparing flash programming
    8. - Start of restoring
    9. - End of restoring
    10. - Target memory read successfully. (512 bytes, 1 range) - Completed after 0.165 sec
    Unfortunately, I really need to call this from a script, so using Jlink Commander would be ideal.
    Can anyone suggest a method to read out the user signature using Jlink Commander?
    Mikkel Holm Olsen
  • Hi Mikkel,
    Yes, this is correct, "savebin" does not use the Openflashloader, and therefore only works, when it is already initialized.
    I added this to our feature request list.
    What you can do, is use J-Flash for this.
    J-Flash is fully usable via command line:
    wiki.segger.com/UM08003_JFlash#Command_Line_Interface
    For now:
    You could call J-Flash with the -readrange command and save the data into a file.
    Then your script could simply open the file and read the data from it.
    Would this work for you?
  • Dear Fabian,
    Thank you for the quick reply. I have just done a little testing, and it appears I can make it work with the following command line:
    1. start /min /wait "J-Flash" jflash.exe -openprjtest.jflash -readrange0x00C00000,0x00C001FF -saveasusig.bin,0x00C00000,0x00C001FF -exit
    Thank you for also adding it to the JLink Commander feature request list.
    Mikkel Holm Olsen
  • Hi Mikkel,
    Good to hear that you are up and running.
