Hi guys any help appreciated
I am following online training and the have suggested using the SWO pin on my nucleo 446RE baord to view the printf data
rather than use the cheap stlink, i thought I would use my J-link EDU, though starting to wish I had not after all the time wasting with it
I can't work out why something so simple seems so hard like splitting the atom ?
so this is the problem
at the moment I am using NUCLEO 446RE dev board and CUBE IDE (which I hate) prefer embeded studio
I enable the debug J-link and SWO option
then when in debug I click the SWV ITM Data Console
Start the trace and get various errors as in bold below ??
and thus no printf data
I have also used the code as per segger website for SWO printf
but don;t think thats the problem
I need to be able to start the trace without errors
Can anyone please help
Thank You
SEGGER J-Link GDB Server V6.80b Command Line Version
JLinkARM.dll V6.80b (DLL compiled Jun 5 2020 17:40:22)
Command line: -port 2331 -s -device STM32F446RE -endian little -speed 4000 -if swd -swoport 2332 -vd
GDBInit file: none
Terminal I/O port: 2333
Generate logfile: off
Verify download: on
Init regs on start: off
Silent mode: off
Single run mode: on
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
Target device: STM32F446RE
Target interface: SWD
Target interface speed: 4000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V11 compiled Nov 2 2020 09:15:32
Hardware: V11.00
S/N: 261000105
OEM: SEGGER-EDU
Feature(s): FlashBP, GDB
Checking target voltage...
Target voltage: 3.33 V
Listening on TCP/IP port 2331
Connecting to target...
Connected to target
Reading all registers
Read 4 bytes @ address 0x0800060E (Data = 0x2DE4E7FB)
Read 2 bytes @ address 0x0800060E (Data = 0xE7FB)
Received monitor command: WriteDP 0x2 0xF0
O.K.
Received monitor command: ReadAP 0x2
O.K.:0xE00FF003
Reading 32 bytes @ address 0xE00FFFD0
Received monitor command: reset
Resetting target
Downloading 452 bytes @ address 0x08000000 - Verified OK
Downloading 11296 bytes @ address 0x080001C4 - Verified OK
Downloading 176 bytes @ address 0x08002DE4 - Verified OK
Downloading 8 bytes @ address 0x08002E94 - Verified OK
Downloading 4 bytes @ address 0x08002E9C - Verified OK
Downloading 4 bytes @ address 0x08002EA0 - Verified OK
Downloading 112 bytes @ address 0x08002EA4 - Verified OK
Writing register (PC = 0x 8000b78)
Read 4 bytes @ address 0x08000B78 (Data = 0xD034F8DF)
Read 2 bytes @ address 0x08000B78 (Data = 0xF8DF)
Read 2 bytes @ address 0x08000B7A (Data = 0xD034)
Reading 64 bytes @ address 0x080005C0
Read 2 bytes @ address 0x08000602 (Data = 0x4803)
Read 4 bytes @ address 0xE000ED14 (Data = 0x00000200)
Downloading 4 bytes @ address 0xE000ED14 - Verified OK
Read 4 bytes @ address 0xE000EDFC (Data = 0x01000000)
Downloading 4 bytes @ address 0xE000EDFC - Verified OK
Read 2 bytes @ address 0x080005E8 (Data = 0xF000)
Setting breakpoint @ address 0x080005E8, Size = 2, BPHandle = 0x0001
Setting breakpoint @ address 0x08000602, Size = 2, BPHandle = 0x0002
Starting target CPU...
...Breakpoint reached @ address 0x080005E8
Removing breakpoint @ address 0x080005E8, Size = 2
Removing breakpoint @ address 0x08000602, Size = 2
Read 4 bytes @ address 0x080005E8 (Data = 0xFAF0F000)
Read 4 bytes @ address 0xE0042004 (Data = 0x00000027)
Read 4 bytes @ address 0xE0001FE0 (Data = 0x00000002)
Downloading 4 bytes @ address 0xE0042004 - Verified OK
Downloading 4 bytes @ address 0xE00400F0 - Verified OK
Downloading 4 bytes @ address 0xE0040010 - Verified OK
Downloading 4 bytes @ address 0xE0000FB0 - Verify failed
Downloading 4 bytes @ address 0xE0000E80 - Verified OK
Downloading 4 bytes @ address 0xE0000E40 - Verified OK
Downloading 4 bytes @ address 0xE0000E00 - Verified OK
Downloading 4 bytes @ address 0xE0001020 - Verified OK
Downloading 4 bytes @ address 0xE0001030 - Verified OK
Downloading 4 bytes @ address 0xE0001040 - Verified OK
Downloading 4 bytes @ address 0xE0001050 - Verified OK
Downloading 4 bytes @ address 0xE0001000 - Verify failed
Downloading 4 bytes @ address 0xE0040304 - Verify failed
Thank You
GDBInit file: none
Verify download: on
Silent mode: off
Single run mode: on
J-Link script: none
Hardware: V11.00
S/N: 261000105
OEM: SEGGER-EDU
Connected to target
O.K.
O.K.:0xE00FF003
Resetting target
The post was edited 2 times, last by johnnysh ().
