OS_Delay never returns
  • OS_Delay never returns
    I'm writing an app on the Renesas RX platform and the GNU RX compiler using the embOS object files.
    I'm calling OS_Delay(100), but the function never returns. I've stepped through the code and it appears I'm in a four-instruction infinite loop inside _OS_DelayUntil:
    FFF87D40 EDAB09 MOV.L 24H[R10],R11
    FFF87D43 437B SUB R7,R11
    FFF87D45 610B CMP #0H,R11
    FFF87D47 29F9 BLT.B 0FFF87D40H
    (For reference, _OS_DelayUntil is at 0xFFF87CDC in this build.)
    Now, I generated my project from scratch rather than using one of the sample projects as a starting point, so my assumption is that I missed some piece of initialization code somewhere. I am calling OS_InitHW() in Rtosinit_GNURX.c.
    Can anyone help me figure out what I may be overlooking?
    -Matthew
    could you please check that your systick timer interrupt runs?
    I guess that your systick interrupt does not work and therefore an OS_Delay() will not work.
    Til
  • It doesn't appear that the systick timer interrupt is firing. I set a breakpoint on OS_ISR_TICK() in Rtosinit_GNURX.c and the breakpoint is never hit. (I tried both a hardware and a software breakpoint.)
    While I'm sure I could debug this with enough effort, the truth is that I'm new to the RX platform. Do you have any tips on chasing this down?
    Thanks!
    -Matthew
  • Hello Matthew,
    you should start with one of our start projects, you could use it as a template when you start with your own project.
    Did you call OS_InitHW()?
    Is the timer working?
    Are Interrupts enabled?
    Til
