[ABANDONED] Error while flashing code
  • [ABANDONED] Error while flashing code
    I'm trying to flash code (based on EmbOS) using IAR Embedded Workbench IDE on a npx imxrt1062 devkit using a j-link plus version 11.
    Sometimes I get an error (see attached image). The strange thing is that I don't always get the error, and sometimes closing and reopening the IDE or changing the j-link solves temporary the problem, while other times these "solutions" are useless.
    Can you help me identifying and solving the problem please?
    Kind Regards,
    Giacomo
  • Hi Giacomo,
    There is no i.MXRT1062 related issue known to us.
    Could you please try if this issue also appears when using the J-Link Commander (jlink.exe) to flash your application?
    Do you see any odd behavior when measuring with an Oscilloscope?
    Does the issue also appear when using another cable (J-Link <-> Device)?
