[SOLVED] FlasherATE multiple files to a single target
  • [SOLVED] FlasherATE multiple files to a single target
    Hello
    I'm setting up a production programming where we need to flash three images per target, e.g. bootloader, configuration, firmware.
    This post asks a similar question but I don't think batch programming would work since the second file is not flashed from the next available address after the first file
    [SOLVED] Flasher Pro/Portable Standalone - Flashing multiple .hex files in to a single target
    I also want to avoid merging the images to a single file since one of the files is custom for each unit and this would add complexity for mass production.
    Can I configure Flasher ATE to automatically flash the images at a specified start address without manual intervention? And if it's not supported out of the box, would a j-link .pex script accomplish it?
    Edit: Seems the #SELECT command would work by creating a different project for each file. Can I call Remote Control commands over the web interface?
    The post was edited 1 time, last by pavel4: added additional information ().
  • pavel4 wrote:
    Hello
    Hello Pavel,
    batch mode also works with the Flasher ATE, so you can use a single project.
    If the custom data for each unit does not exceed the limit of the #auto patch command, I recommend to use this one instead of uploading new files. Uploading new files is always an operation on the NAND flash of the modules and always costs some endurance.
