[SOLVED] Segger Embedded Studio ARM5.1 Project: Call from section .text.libc.__aeabi_errno_addr made to __aeabi_read_tp but __aeabi_read_tp is a symbol without the low bit set
  • [SOLVED] Segger Embedded Studio ARM5.1 Project: Call from section .text.libc.__aeabi_errno_addr made to __aeabi_read_tp but __aeabi_read_tp is a symbol without the low bit set
    Dear Segger Forum,
    after updating to Segger Embedded Studio ARM5.1 I got the following Linker Error:
    "C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 5.10b/bin/segger-ld" --defsym=__STACKSIZE__=4096 --defsym=__STACKSIZE_PROCESS__=4096 --defsym=__HEAPSIZE__=64000 --full-section-headers -ereset_handler --defsym=__do_debug_operation=__do_debug_operation_mempoll -EL -mcpu=7E-M --defsym=__vfprintf=__vfprintf_float_long --defsym=__vfscanf=__vfscanf_int --silent --list-all-undefineds --fatal-warnings --gc-sections "-TC:/Users/so/Documents/Repos/Z-Platform-Projects/Analog-Out-Modul-STM32L452-Config/emStudio/Linker Script File/STM32L452RETX_FLASH.icf" --map-text --map-file=Debug/ecom-Analog-Out-Modul.map --map-standard --log-file Debug/ecom-Analog-Out-Modul.log -u_vectors -o Debug/ecom-Analog-Out-Modul.elf --emit-relocs --start-group @C:/Users/so/Documents/Repos/Z-Platform-Projects/Analog-Out-Modul-STM32L452-Config/emStudio/Debug/ecom-Analog-Out-Modul.ind --end-group
    Thank you for your inquiry and keeping us updated.
    We will mark this thread as solved now so others can find this thread in future.
