SystemView 3.12 Read Recorded Data not working
    • SystemView 3.12 Read Recorded Data not working
      In SystemView 3.12 the function "Read Recorded Data" is not working in post-morten mode. When I click on the menu item nothing happens. I know the trace buffer is okay because I can manually download the trace and concatenate the two buffer pieces, as described in the SystemView Guide section 3.11.3 Post-mortem analysis, and load the data in SystemView.
      I can see on the forum that others have the same problem. Please address the issue.
      Best Regards,
      Ulrich
    • Hello Ulrich,
      Do you see the same behaviour with SystemView V3.20?
      What target device are you debugging exactly?
      Could you provide a J-Link log of the SystemView session?
