[SOLVED] Data breakpoints data mask
  • [SOLVED] Data breakpoints data mask
    Hi!
    I need to create a mask for a data watchpoint (in particular for the upper bytes of a 32bit word) but I am not able to make it work.
    I am working on a Renesas RZ/A1 (Cortex-A9) with e2studio as IDE and SEGGER J-Link V6.44i for debugger.
    From the SEGGER J-Link control panel I am able to set a Data Breakpoint (and it works) but any attempt to use the mask functionality failed: the breakpoint is always hit regadless the value written.
    This is my example setting if i try to use the data pattern 0x1000xxxx :
    Some additional information:
    1. I can't use newer J-Link version because, after the V6.44i, a web control panel has been introduced and I am not able to create Data Breakpoint anymore. No idea why.
    2. I am not able to create Data breakpoint directly from the IDE (e2studio).
    3. I tried to use, as a workaround, an address mask of 1 byte (targeting the upper bytes of a uint32_t variable for example) but the breakpoint is hit for the whole 32bit word.
    For giving a bit more of context, I am debugging an issue where sometimes a variable is corrupted with abnormally high values. This variable is written (voluntarly) several times in a second while the bug happens in a variable time from minutes to 1 week(!!).
    Could you please help me? :/
    Thank you!
    Regarding the missing break point feature:
    We will see if we can add this feature to the Web Control panel as well.
    Regarding the issue at hand:
    I would recommend using Ozone to debug your device.
    It has a data breakpoint feature as well, which is also well documented in the Ozone Manual.
    It is available for download here and free for evaluation purposes.
    Does this work for you?
  • Hi everyone,
    Quick follow up.
    We just implemented this feature for the J-Link Web Control panel.
    It will be available in the next beta release and in the next full release (V7.56).
