[SOLVED] Target Connection Lost when attaching to running program
  • [SOLVED] Target Connection Lost when attaching to running program
    Hi
    My application has a bootloader which runs in the K60 internal flash, then jumps to an entry routine in an external flash bank.
    I can debug the bootloader perfectly, but as the transition to loading the external flash code is proving tricky, I'm looking for a more straightforward approach to debugging the external flash code, which I think might be achieved by the 'attach to running program' option.
    I'm using a 'default' jdebug project (haven't commented anything in/out), and am seeing the 'Target Connection Lost' message (see attached) following the attempt to connect Ozone to the running target- Any ideas as to what might cause this issue?
    Many thanks
    David
    When you have a bootloader part and application part where you want to debug only the application we recommend to just load the bootloader part before your application part is downloaded:
    wiki.segger.com/Debug_Bootload…der_and_debug_application
    Your application will then be downloaded via the elf file you provided to the File.Open function and for this application also all debug symbols will be available.
    Then just make sure that your bootloader runs through as explained here:
    wiki.segger.com/Debug_on_a_Target_with_Bootloader
    Now on start of the debug Session Ozone will let the bootloader and then the application run until the startup completion point (usually function main()) is hit where the first automatic breakpoint is set.
    From then on Ozone has full control over the debug session and you can debug your application as usual.
    But you have to make sure the application image makes it to the Flash by having a Flashloader for that external Flash as explained in your other thread:
    Ozone hanging when loading code into external flash
