[SOLVED] [Python] Reading from SEGGER RTT print via Jlink Compact instead of a wired UART connection
  • [SOLVED] [Python] Reading from SEGGER RTT print via Jlink Compact instead of a wired UART connection
    We would like to access the print outputs of the SEGGER_RTT_WriteString() function via a JLINK compact debugger using Python.
    The latter is wired only via SWDIO, SWDCLK, VMCU and GND of the nRF52840 IC.
    Is there a clever way to do this in order to not use a wired UART connection.
    example:
    Hereby we would replace
    printf("\r\nUART started.\r\n");
    (which can be read in python by using pyserial readlines())
    with
    SEGGER_RTT_WriteString(0,"\r\n RTT started.\r\n");
    and read this string in Python.
    Thanks in advance,
    Kind regards,
    Tom
  • Hi Tom,
    There are two ways to achieve this:
    1) You could acquire the J-Link SDK, which comes with an RTT Python sample as well as
    a python library to control J-Link including RTT:
    2) You could read the RTT data via the TELNET channel:
    wiki.segger.com/RTT#TELNET_channel_of_J-Link_software
    If you would be interested in option 1) I would suggest you contact us regarding this via our Support Ticket System
    (please see my signature below this post for the link).
