[SOLVED] Segger firmware update killed the debugger
  • [SOLVED] Segger firmware update killed the debugger
    Hi
    I have a J link base debugger. Been a while since I used it and plugging USB in prompted for firmware update of the debugger
    After that finished, the LED does not come on any more, and windows device manager lists it as "unknown device" (Segger is reputed to be top class, but a firmware update killing the debugger is not very top class)
    Any hints how to proceed?
    Klaus
  • Hi Klaus,
    I assume that the SN of the Probe you are using is the one you registered with?
    If so, it is most likely that you are not using a genuine J-Link but a clone.
    From our database, the J-Link with this SN was already sent back to SEGGER and destroyed one and a half years ago.
    To be absolutely sure, could you please send us a photo of the front and the back side of the probe?
  • Hi Fabian
    Sure, the images is attached
    And if they are counterfeit, I have a technician that I need to talk to, to find where he bought it
    Anyway, in the meantime I wrote to my SW colleagues, and they have several that I can borrow instead. They are for sure genuine :)
    Thanks for your quick response, I guess Segger is top class anyway :)
    Klaus
  • Hi Klaus,
    This is indeed a clone.
    Good to hear that you have other J-Links you can use and therefore that you are not stuck in your work-flow :)
    A list of our legitimate distributors can be found here:
    segger.com/purchase/distributors/
    Even though I am sure you were not aware that this is a clone,
    I have to point out that the usage of J-Link clones in any context is illegal.
  • I just got the real Seggers from work. They sure have a different feel to them. We have problems at work getting them to function with IAR, so we have plenty not being used. I am using STM32CubeIDE, so I hope they will work for my usecase
    Thanks for your help
    Klaus
    PS And yes, I know it is illegal with the counterfeit ones, we did not know they were.
  • Hi Klaus,
    Good to hear that you were able to replace it so quickly.
    Please let us know if anything does not work as expected.
    I will close this thread for now.
