[SOLVED] Error while determining flash info
  • [SOLVED] Error while determining flash info
    I'm running my J-Link base from J-Link Commander V6.62d. When I try to erase my SAME54P20 via SWD, I get an error message "Error while determining flash info". I suspect this is a benign error, since the flash appears to be erased after this command. Is this a known problem, or a user error? Full printout below:
    SEGGER J-Link Commander V6.62d (Compiled Mar 2 2020 09:23:14)
    DLL version V6.62d, compiled Mar 2 2020 09:22:41
    Firmware: J-Link V10 compiled Jan 7 2020 16:51:47
    Hardware version: V10.10
    S/N: 50123455
    License(s): GDB
    VTref=3.305V
    J-Link>connect
    Please specify device / core. <Default>: ATSAME54P20
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>s
    Speed>
    Device "ATSAME54P20" selected.
    Connecting to target via SWD
    InitTarget() start
    InitTarget()
    InitTarget() end
    InitTarget() end
    DPIDR: 0x2BA01477
    AP[2]: Stopped AP scan as end of AP map seems to be reached
    AP[1]: AHB-AP (IDR: 0x74770001)
    AP[0]: Core found
    AP[0]: AHB-AP ROM base: 0x41003000
    CoreSight components:
    ROMTbl[0] @ 41003000
    ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C4 ROM Table
    ROMTbl[1] @ E00FF000
    ROMTbl[1][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    ROMTbl[1][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
    ROMTbl[1][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
    ROMTbl[1][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[1][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[1][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    ROMTbl[1][6]: E0042000, CID: B105900D, PID: 003BB907 ETB
    Cortex-M4 identified.
    J-Link>erase
    Erasing device...
    J-Link: Flash download: Total time needed: 4.958s (Prepare: 0.080s, Compare: 0.000s, Erase: 4.873s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
    J-Link: Flash download: Total time needed: 0.040s (Prepare: 0.019s, Compare: 0.000s, Erase: 0.017s, Program: 0.000s, Verify: 0.000s, Restore: 0.004s)
    ****** Error: Failed to prepare for programming.
    Error while determining flash info (Bank @ 0x04000000)
    ERROR: Erase returned with error code -1.
    You are using an out-of-date version of the J-Link Software.
    It is recommended to always update to the latest version.
    Could you please update to the latest version and try again?
    At Address 0x04000000, the QSPI is expected.
    Does the chip you are using have a QSPI connected?
    Usually, J-Link does not try to erase external flash banks except
    "exec EnableEraseAllFlashBanks" is passed in the commander.
    Should this still happen with the latest version, please tell us and we will look into this.
    If so, you could use the "erase <StartAddr>, <EndAddr>" command and only select the available flash address range,
    until this is resolved.
