[SOLVED] CTRL-C not working in Project Explorer
  • [SOLVED] CTRL-C not working in Project Explorer
    Hello Segger Team,
    When trying to copy a selected Folder in the Project Explorer via the shortcut CTRL-C/CTRL-V it is always failing until using the Copy-Function from the context-Menu. After using this, the CTRL-C-Copy is also working.
    You can reproduce it with the default Project when copying the Setup Folder into the Source folder, or vice versa.
    The issue is reproducible and will be fixed in future.
