Hello Segger Team,
When trying to copy a selected Folder in the Project Explorer via the shortcut CTRL-C/CTRL-V it is always failing until using the Copy-Function from the context-Menu. After using this, the CTRL-C-Copy is also working.
You can reproduce it with the default Project when copying the Setup Folder into the Source folder, or vice versa.
