[ABANDONED] cstddef and stddef.h in cpp file error
  • [ABANDONED] cstddef and stddef.h in cpp file error
    Creating a default executable C/C++ project and simply using the following main code causes the following error: "cannot combine with previous 'int' declaration specifier"
    1. #include <cstddef>
    2. //#include <stddef.h> // doesn't work either
    3. int main() {
    4. }
    Could you provide a bit more information about your setup?
    What version of ES are you using?
    How is your project set up? Which Run time library, which linker, which compiler etc.?
    To simplify things, could you provide an example project with which the issue is reproducible?
