[SOLVED] C-compiler generates unaligned strd instruction - hard fault
  • [SOLVED] C-compiler generates unaligned strd instruction - hard fault
    I have a C-project which runs on NRF52832 (cortex M4). Using Segger Embedded Studio Release 5.10b (Build 2020091601.43513 Linux x64), segger-cc: version 10.6.6.
    My issue is the compiler generates an strd instruction using an unaligned address, which causes a hard fault when I run it.
    C-code:
    1. int mbedtls_sha256_starts_ret( mbedtls_sha256_context *ctx, int is224 )
    2. {
    3. SHA256_VALIDATE_RET( ctx != NULL );
    4. SHA256_VALIDATE_RET( is224 == 0 || is224 == 1 );
    5. ctx->total[0] = 0;
    6. ctx->total[1] = 0;
    7. if( is224 == 0 )
    8. {
    9. /* SHA-256 */
    10. ctx->state[0] = 0x6A09E667;
    11. ctx->state[1] = 0xBB67AE85;
    12. ctx->state[2] = 0x3C6EF372;
    13. ctx->state[3] = 0xA54FF53A;
    14. ctx->state[4] = 0x510E527F;
    15. ctx->state[5] = 0x9B05688C;
    16. ctx->state[6] = 0x1F83D9AB;
    17. ctx->state[7] = 0x5BE0CD19;
    18. }
    19. else
    20. {
    21. /* SHA-224 */
    22. ctx->state[0] = 0xC1059ED8;
    23. ctx->state[1] = 0x367CD507;
    24. ctx->state[2] = 0x3070DD17;
    25. ctx->state[3] = 0xF70E5939;
    26. ctx->state[4] = 0xFFC00B31;
    27. ctx->state[5] = 0x68581511;
    28. ctx->state[6] = 0x64F98FA7;
    29. ctx->state[7] = 0xBEFA4FA4;
    30. }
    31. ctx->is224 = is224;
    32. return( 0 );
    33. }
    When compiling with optimization level 0, everything runs fine.
    However, when changing optimization level to 1 (and above), the following code is generated by the compiler (only parts of generated code shown):
    1. 6681 str r1, [r0, #0x68]
    2. F04F0C00 mov.w r12, #0
    3. F64473A4 movw r3, #0x4FA4
    4. F6CB63FA movt r3, #0xBEFA
    5. 2900 cmp r1, #0
    6. BF04 itt eq
    7. F64C5319 movweq r3, #0xCD19
    8. F6C533E0 movteq r3, #0x5BE0
    9. F64872A7 movw r2, #0x8FA7
    10. F2C642F9 movt r2, #0x64F9
    11. BF04 itt eq
    12. F64D12AB movweq r2, #0xD9AB
    13. F6C17283 movteq r2, #0x1F83
    14. E9C02308 strd r2, r3, [r0, #32]
    The issue is the last line (#14), causing a hard fault because the address in r0 is 0x2000637a which is not 32-bit aligned. Changing the address to 0x2000637c before executing the line causes no hard fault.
    Edit: The address in question (0x2000637a) is the first parameter in the function (*ctx).
    The question is; is this caused by me and something I have configured wrong in my project? Or is this a bug in the compiler?
    Best regards.
    The post was edited 1 time, last by cnaess ().
    Could you provide a project for reproduction which runs on an eval board?
    We took a look at your example code. According to the addresses you see when debugging, 0x2000637a is not aligned correctly which means that your struct is called/used incorrectly. It should be 4 byte aligned but is 2 byte aligned instead.
    This is not a bug in the compiler but incorrect usage of the C language.
    It is pure luck that gcc creates other code here that runs by accident.
    We recommend to revisit your application and how that struct is used.
  • Hi, thank you for taking the time to look into this.
    The address of the struct (0x2000637a) is assigned by the compiler. I'm not sure how I can instruct the compiler to use a 4 byte aligned address instead?
    Here's the code where it's assigned (the struct is ctx).:
    1. int mbedtls_sha256_ret( const unsigned char *input,
    2. size_t ilen,
    3. unsigned char output[32],
    4. int is224 )
    5. {
    6. int ret;
    7. mbedtls_sha256_context ctx;
    8. SHA256_VALIDATE_RET( is224 == 0 || is224 == 1 );
    9. SHA256_VALIDATE_RET( ilen == 0 || input != NULL );
    10. SHA256_VALIDATE_RET( (unsigned char *)output != NULL );
    11. mbedtls_sha256_init( &ctx );
    12. if( ( ret = mbedtls_sha256_starts_ret( &ctx, is224 ) ) != 0 )
    13. goto exit;
    14. if( ( ret = mbedtls_sha256_update_ret( &ctx, input, ilen ) ) != 0 )
    15. goto exit;
    16. if( ( ret = mbedtls_sha256_finish_ret( &ctx, output ) ) != 0 )
    17. goto exit;
    18. exit:
    19. mbedtls_sha256_free( &ctx );
    20. return( ret );
    21. }
    mbedtls_sha256_init:
    1. void mbedtls_sha256_init( mbedtls_sha256_context *ctx )
    2. {
    3. SHA256_VALIDATE( ctx != NULL );
    4. memset( ctx, 0, sizeof( mbedtls_sha256_context ) );
    5. }
    Here's the definition of the struct:
    1. typedef struct mbedtls_sha256_context
    2. {
    3. uint32_t total[2]; /*!< The number of Bytes processed. */
    4. uint32_t state[8]; /*!< The intermediate digest state. */
    5. unsigned char buffer[64]; /*!< The data block being processed. */
    6. int is224; /*!< Determines which function to use:
    7. 0: Use SHA-256, or 1: Use SHA-224. */
    8. }
    9. mbedtls_sha256_context;
    Could you please suggest how to change the code in order for the compiler to assign a 4 byte aligned address to ctx?
    Thank you.
    Thank you for providing additional details.
    I can't see anything wrong with this code.
    The local variable 'ctx' is placed on the stack by the compiler, and because it contains a 'uint32_t', it will always be 4 bytes aligned (relative to the sp register).
    That means: Either the stack pointer was not setup correctly (sp must always be 4 byte aligned !) or the alignment was switched off by any unusual compiler directive (like -fpack-struct, -mstack-alignment, #pragma pack, .....)
    Are you using "stock" Embedded Studio or one with Nordic plugins/modifications. Could you attach your emProject file for reference to check if no project options are active that might cause this behaviour?
    If using a modified version of ES. Do you see the same behaviour with stock ES?
  • Hello and sorry about the late follow up.
    I finally had time to look into this. And after examining my project further I discovered the option "Unaligned Access Support" was set to "Yes". Changing this configuration to "No" resolved my issue.
    Thanks for your help!
