[SOLVED] FreeRTOS + Nordic thread awareness scripts
  • [SOLVED] FreeRTOS + Nordic thread awareness scripts
    I spent some time getting thread awareness scripts working for FreeRTOS on a Nordic nRF52840 device and thought I'd share my findings in case anyone else is having similar issues.
    I'm using SES 5.10b on Windows 10, and I started by going into Project Options, Debug, Debugger, and set the RTOS Awareness option to FreeRTOS CM4. This should automatically change the Threads Script File option to $(StudioDir)/samples/FreeRTOSPlugin_CM4.js.
    When I then debugged the app, I received several error popups when hitting a breakpoint, usually in the functions GetTCB or GetTaskName in the script file.
    I traced the issue to the update function in the line:
    MaxPriority = Debug.evaluate("uxTopReadyPriority");
    In the default Nordic FreeRTOSConfig.h, configUSE_PORT_OPTIMISED_TASK_SELECTION is 1, which sets uxTopReadyPriority up as a bitmap and confuses the script. The quickest way I found to fix it was to disable configUSE_PORT_OPTIMISED_TASK_SELECTION for my Debug configuration, e.g.
    #define configUSE_PORT_OPTIMISED_TASK_SELECTION ( DEBUG ? 0 : 1 )
    I did not require it, but note that there is also a portREMOVE_STATIC_QUALIFIER option you can define which may help if you have issues with older versions of SES or FreeRTOS (see comment in FreeRTOS tasks.c).
    The older threads_CM4F.js script from the SEGGER Wiki page also worked.
    I'm also using Monitor Mode Debugging, so the combination of these two features has been very helpful (thank you SEGGER).
    I hope this information is useful to someone.
    The post was edited 1 time, last by kklobe: fixed incorrect Threads Script File value ().
  • Thanks, really useful.
    Can you share your experience of using the debug monitor with nrf52840?
    I would like to see how to properly configure it for this chip. If I understand correctly, the monitor will not work on DK. Are you using a tracer?
