[SOLVED] Error reading from memory
  • [SOLVED] Error reading from memory
    Hi everyone,
    I am using Cypress FM4-S6E2CC-ETH with J-link EDU as my development tool. I have already build a project on Keil and I wanna change my development platform to Segger Embedded Studio. Thus, I use" Project -> import Project -> import Keil MDK Project" to transform the project
    But the problem come out which show in the attachment
    it shows that there have some issue for reading from memory, but I google for it, can't find any useful information.
    Can anyone have the idea what is the problem? Thanks!
    Jeff
  • Hello Jeff,
    It appears that the imported project is not yet set up correctly.
    How to use the import tool is described here for IAR:
    wiki.segger.com/Port_Projects_…kbench_to_Embedded_Studio
    But the same/similar steps apply for Keil.
    Our recommendation for more complex project is not to use the import tool but rather create a new project with the Embedded Studio project wizard for the internal toolchian only, then add the sources from your other project manually and adjust linker/compiler errors.
    That is usually the faster solution especially if you are looking to switch to the Embedded Studio toolchain generally.
