[SOLVED] Linux: wrong version shown?
  • [SOLVED] Linux: wrong version shown?
    I *think*, Ozone is showing the wrong version in the window's title bar in V3.20e. It says V3.20c here. V3.20d was fine.
    I downloaded Ozone_Linux_V320e_x86_64.tgz but title bar and About dialog say V3.20c.
    I still see the possibility that the issue could be caused by the package manager (pacman on Arch) since I am not very familiar with it yet but I still wanted to let you know, so you can maybe reproduce the problem.
    Cheers
    I just gave it a quick try on a Ubuntu18 VM and the versions were showing up correctly for both the deb and tgz.
    Most likely this is somehow related to your specific Linux config.
    I am not sure what went wrong but when I created the Arch package completely anew, removed the installed version and installed the new package, the version was correct.
    I think before, it downloaded the e version but built the c version which was still there in the package folder, but named it after the e version. Weird.
    This can be closed then. :)
    Cheers
