[SOLVED] Serial number programming. Jflash always asks for the file "...project_SNList.txt"
  • [SOLVED] Serial number programming. Jflash always asks for the file "...project_SNList.txt"
    Hello again.
    I have a problem with JFLASH (V6.84) that was solved some months ago in this other thread.
    I want to program the serial number using the file "..._Project_Serial.txt". However, Jflash always asks for "_Project_SNList.txt", as you can see in the attached image.
    Although I don't use "_Project_SNList.txt", the serial number and the program are correctly saved in memory. The problem is that JFLASH returns ERRORLEVEL = 1, so my batch file fails all the time (see attached image).
    We are sorry for the delay in response. We have been very busy with pressing projects for the last weeks.
    Good to hear that the issue has been resolved.
    Hardwariano wrote:
    Although I sent a ticket explaining the issue, I didn't get any response
    This should not have happened.
    Could you please tell me the inquiry number of the ticket you opened?
    as the issue was resolved now, we will close this thread.
    We are sorry for any inconvenience caused.
