[SOLVED] Data sampling for array data
  • [SOLVED] Data sampling for array data
    Kindly, can you tell me if you can view the data on the chart, presented in the form of an array?
    Or do you need to write a special function that will copy one point at a time into a variable that is already displayed?
    It doesn't look bad as long as there are few points. but with a large number of points, this will slow down all systems.
    Best Regards,
    Max
  • Hello Max,
    You can display the data in a table in the Data Sampling window in the Samples tab.
    If you right click the content you can also export it.
    This is a bit different from what I would like. I am sorry, I can not always correctly formulate a thought in English :(
    Look, I have an array of data that I receive from a sensor, such as an accelerometer.
    I get 10 points on 3 axis every 100ms.
    int16_t accData[3][10];
    Is there a way to graphically display these 10 points?
    At the moment, I can display one point on the chart (timeline) accData[0][0]
    Maybe there is some kind of circular buffer, FIFO, into which I can add data to be displayed?
    Thank you for clarifying.
    This is currently not possible.
    But we will add it to our wishlist for future features for Ozone.
