MEMDEV Issue..
    • MEMDEV Issue..
      Hi All,
      Recently, i have testing memory device Because of the flickering.
      I've attached my application test code below.
      My hardware is stm32f767IGT6 with SDRAM using FMC.
      I have two png file to display in 320x240 LCD.
      Because of the flickering, I'd like to use MEMDEV or MULTIBUF.
      First i tried to use Multi Buf. but it's not works with hardfault So, i'm trying to use MEMDEV.
      The test code has 2 images.
      In MainTask,
      If the "test" is true, the smile guy is displayed properly.
      but "test" is false, sysytem crush, with hardfault()
      Of course if not using MEMDEV, displayed properly.
      void MainTask(void)
      GUI_MEMDEV_Handle hMem = GUI_MEMDEV_Create(0, 0, 320, 240);
      GUI_MEMDEV_Select(hMem);
      GUI_Clear();
      if(test)
      GUI_PNG_Draw(_acBitmap_50x50, sizeof(_acPNG), 0, 0);
      else
      GUI_PNG_Draw(background, sizeof(background), 0, 0);
      GUI_MEMDEV_CopyToLCD(hMem);
      while (1)
      GUI_Delay(100);
      What am i doing wrong?
      • question.zip
        (117.04 kB, downloaded 60 times, last: )
      The post was edited 1 time, last by swan3708 ().
      first of all, you should make sure that GUI_Init() has been called at the beginning of your program.
      Then, after your drawing operations in a memory device are finished, you have to deselect the memory device by calling GUI_MEMDEV_Select(0).
      If the above steps did not help you, you should make sure that you have enough memory for the PNG images and the memory device.
      Florian
      Check out the manual for the memory requirements to draw PNGs:
      segger.com/doc/UM03001_emWin.html#id_000799
      Here is a description on how much memory a memory device requires:
      segger.com/doc/UM03001_emWin.html#Memory_requirements
      I doubt that 400KB are sufficient memory. You might want to try out other formats than PNG instead. You could use the Bitmap Converter to generate a DTA file from the PNG. Drawing a DTA doesn't need that much memory. Also the Bitmap Converter offers different options to keep the image file small.
      Just take a look here for a detailed description about the possibilities of the Bitmap Converter:
      segger.com/doc/UM03001_emWin.html#Bitmap_Converter
