Hello, I met a bug.
Hotkeys are not always perceived correctly depending on the keyboard layout.
- In the settings menu, the current layout does not affect and allows you to assign a new keyboard shortcut correctly, taking into account the English layout;
- In the code editor, hotkeys work correctly when the English layout is enabled
- When Russian (for example) is enabled, the combinations stop working completely. But with a few exceptions "Ctrl + Q".
In the screenshot, I tried to call the "open file in explorer" option using the "Ctrl + Q, E" combinations with the Russian layout enabled (For example, I forgot to change the layout when returning to SES
![](https://forum.segger.com/index.php/Attachment/4299-ctrl-q-e-png/?thumbnail=1)
As you can see, the combination was only partially recognized.
This is not critical, but in some ways it is not convenient.
Thank,
![:/](https://forum.segger.com/wcf/images/smilies/unsure.png)
Thank,
