faced the following problem.
I am creating a new project for the nrf52840 microcontroller, with standart parameters:
After, run build. But it's not successfully:
Build failed
What's happen? Previously, the project was created without any problems and was assembled with default settings.
if your need, project available here
P.s
System Windows 8.1 Pro
SES: 5.10 x64
Maxim
- Building ‘devkit’ from solution ‘devkit’ in configuration ‘Debug’
- Compiling ‘system_nrf52840.c’
- Compiling ‘SEGGER_RTT.c’
- Compiling ‘SEGGER_RTT_SES.c’
- Compiling ‘main.c’
- Assembling ‘SEGGER_THUMB_Startup.s’
- Assembling ‘ses_startup_nrf52840.s’
- Assembling ‘ses_startup_nrf_common.s’
- Linking devkit.elf
- relocation R_ARM_THM_CALL to Arm-mode function not supported on this core, from .init to afterInitialize
- See https://wiki.segger.com/Correct_typing_of_Thumb_functions for help on correcting this
- Call from section .init made to afterInitialize but afterInitialize is a symbol without the low bit set
- Build failed
P.s
SES: 5.10 x64
Maxim
